100 % Stock Mazda Mx3 K8
And now some news on the project:
I've painted my dashboard, in a purple color that matches the fabric on the OEM seats and placed the radio one level down
I've placed a GroundWire kit from MazdaSpeed
I've placed a start button on my dashboard
I've placed a race mode kit button on my dashboard
I've placed some black housing Altezza
I've placed some real xenon driving light's
I've placed a real alarm on the car
I've placed some Alpine 2 separated way's speakers on the front
I hope to have more news soon
ET: 15.567 @ 136 kmh (84 mph)
OutlaW666 schreef:All button's are GOING to work, since i am no electrician and i dont want to mess the car up.
In a few days ill connect them.
The race mode it's for show only ... unless i am liyng :D
haha... way 2 go!!
if you can get that starter button to work plz let us know, i am interested in how you connect this up to the ignition on the steering wheel!!
keep up the good work!!
turbulence schreef:OutlaW666 schreef:All button's are GOING to work, since i am no electrician and i dont want to mess the car up.
haha... way 2 go!!
That would be awesome! A start button in an mx-3!
I can start the car from 400m with a remote control but i guess the start button works the same way but without using a signal.
The only thing i can think of is; What if people break into your car and they simply press the button and the engine starts and they can drive away?
Would be cool if you could write a how to and a solution how to prevent such thing from happening.
I know you could buy some sort of a card reader on the market where you have to put a card in the reader and then you can start the car, without the card it won't work.
Artist Profiel:: http://partyflock.nl/artist/27846.html
het is vrij gemakkelijk om de start knop aan te sluiten .
je moet het zo maken dat je alleen kan starten als de sleutel op het contact staat .
je moet dan meten welke draad 12 volt aangeeft bij het contact
let wel , deze moet wel 12volt blijven geven als je de motor start
dan soldeer je daar een draadje aan , en die zet je op de druk knop
en je meet welke draad 12 volt geeft als je de motor start.
en zodra je de sleutel dan los laat , dan moet de spanning weg vallen
op deze draad soldeer je ook een draad , en deze gaat na het andere aansluitpunt van de druk knop.
let wel op , gebruik niet te dunne draad hiervoor.
liefst gewoon dezelfde dikte als de draden van het contact slot
