Hi Tom,
Nice to see you're still visiting the greatest club of Eur....
- Ofcourse, first you remove all the plastic stuff,
- then the two plugs of the window heating, left and right.
- Then you remove the one or two nuts, you'll see them easily.
- You remove the rubber from the outside. Maybe, when you are lucky, you can pull it out and keep the rubber at one piece. Otherwise you have to slice it with a knife (and you buy a new one).
- The hole window is glued, you will have to slice the glue with a special tool for this ( a window-glue-slicer
). It's a sharp metal wire, with two handles, see the pictures.
You have to do it carefully!! with two persons (because the window can brake).
Please take your time for it!
![Afbeelding](http://img.tweedehands.net/pics/00/04/32/95/02/1b.jpg)
Good luck and lets us know if you succeed!
Greetings M&M
