ik wou vandaag me tps afstellen, dus how to uitgeprint en aan de slag. Nadeel was alleen dat de foto's het niet meer doen en ik dus niet weet welke draad ik moet hebben
dus kan iemand mij vertellen welke van de 4 ik moet hebben?? Dus bv de 2de van onder.
groeten jeroen
TPS Afstellen.
- Dikkekobus
- Dikkekobus
TPS Voltage Check
Ensure no accessories - radio, fan, defrost etc are all switched off.
Turn ignition key to ON and ensure TEN and GRD are jumped.
Connect ground of voltmeter to Negative on Battery.
Connect other voltmeter lead to the Y wire (second wire from top) from the TPS connector (A long thumbtack or needle will be needed to pierce the wire shiething. Then connect the voltmeter lead to the thumbtack/needle).
At closed throttle which you are now at, you should get a voltmeter reading of .1V to 1.1V. Rotate the throttle linkage by hand to wide open throttle (WOT) and record voltages again. WOT voltage should be 2.8V to 4.5V.
If voltage readings are not within specified tollerances, than TPS replacement will be in order.
To make a final check if voltages are within spec, rotate throttle linkage slowly from closed to WOT and back several times observing for any inconsistant fluctuations. This is best done with an annalog voltmeter if available, since these fluctuations will be very difficult to pick up on an electronic voltmeter.
Remove thumbtack/needle and voltmeter.
Re-install all intake items.
Leave TEN and GRD in DIAG box in plave.
- Dikkekobus
