Ksport Big Brake kit.
- MazdaMx-3 Sponsor
Deze kit is er nog niet maar ik moet er 10 minimaal laten maken.
Ik zoek nog vrijwilligers om te meten of dit ook op de niet gechekte modellen past.
Zover ik nu weet past deze kit op:
- MX-3 V6 (checked)
- MX-3 i4
- 323F BA 1.8 (checked)
- 323F BA 1.5
- 323F BG 1.8
- 323F BG 1.6
- 323 BG HB
- 323 Sedan
Past niet op:
- 323F BA V6 (checked)
Prijs normaa € 1499,-
Voor club leden: € 1299,-
meer info: www.jeroentje.nl
http://www.jeroentje.nl/index.php?page= ... d=70100750
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
8-Piston Aluminum calipers
High quality brake pads
D.O.T. Compliant Stainless steel brake lines
Machined aluminum hats
Carbon steel brackets
330mm (13") large ventilated discs (17" wheels required)
Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
- MX-3 V6 (checked)
- MX-3 i4
- 323F BA 1.5
- 323F BG 1.8
- 323F BG 1.6
- 323 BG HB
- 323 Sedan
Past niet op:
de 1,6 heeft hetzelfde remsysteem als de v6!
dus op de 1,6 beide modellen dus de sohc en de dohc past het 100% zeker!
ps.
geef je je hier op voor de groupsbuy??
of maak je daar een andere lijst voor??
ik wil iig een set!!
heb je ook nog info hoe lang het kan duren als er 10 man zijn tot de set gemaakt is?
neem aan dat er alleen brackets en hoedjes voor de schijven gemaakt hoeven worden en dat de rest standaard is!
ps.
- MazdaMx-3 Sponsor
zover ik nu kan zien moet het op alle mx3en passen.
ik zou het graag een keer nameten dus als iemand zich geroepen voelt om even langs te komen
het is de brackets.. binnenkant schijf en leiding met de goede lengte.
Tot nu toe gaat het niet erg goed.
4 setjes zit ik op.. maar op MX-3.com is het er al af gegooit.. was te veel reclame vonden ze.
Dat schiet niet op.
NU nog in Duitsland posten.
welk forum moet ik daar hebben ?
Dat schiet niet op.
- JD GRAFFIX
- JD GRAFFIX
Just dont get it.....I have sent emails to his private adress and the normal adress from the site but I get no reactions at all.
Maybe some one else wants to try..........
SideSkirts on Back order :-(
