Nitrous Fusion is Overleden.............Mikee Blows the KL-Z
JD GRAFFIX
Bericht door JD GRAFFIX »
Ok guys I want to give you my version of what happens before you all ask yourselfs what happened.
On the Saturday morning we drove to Donky's garage and replaced my motor mounts for a stronger set, after that I connected a new switch to the NOS Arm system. The NOS activator I had already replace in NL.
We took the car out of the garage where I launched the car on the parking area with Sam sitting next to me. Turned right out of the garage and floor it !!
The new clutch and the engine mounts we're doing fine, so as I went to turn around I opened the Nos bottle and flicked on the ARM switch.......pssssssss I heard the noise so I turned the engine off while Sam and I looked under the motorkap. The whole of the Intake manifold was frozen......the new Activator switch was stuck open.....I run to turn the bottle off and pull the key out of the ignition......I turned the key just a bit the wrong way...CONTACT!!!!!BANG!!!!!!!!!!!
Well the rest is history......Game Over.....The Intake manifold, throtle body , VAF and a few other things all where destroyed....
after a good inspection it turns out that the New Activator Switch I had bought worked on Reverse, compared with the switch I had....so it was always on...Aint that a bitch!!
Thanks to Bart, we drove back in his car...all four of us and our dog...
got back picked up Barts Bus and a car trailer...drove all the way back....picked the car up and then drove back....hahahhahahhah
2500kms in 3 days!!!
A special Thanks to Donky for letting the car stay in the garage all night and helping us in the way that you did.....really appreciated it....
Well the story continues...The car is at Jeroentjes ...the new engine is on its way, the turbo and a load of other goodies are all ready here waiting........so
The RESURECTION is coming.
SideSkirts on Back order :-(
hyperman
Bericht door hyperman »
Dawm that really sucks especially when you are far away from home. Hope you get him back up and running soon.
good luck Mikey with your new engine ;) was very fucked up when i here the Kaboem :cry: it was a loud noise from the engine
yeah that's realy fuckt up :nut: everybody was not in a good mood wen they pusshed your car to the garage :cry:
Succes ermee man !!
Hoop dat je volgende blok wel iets versterkt wordt als je ook nog een turbo erop gaat zetten
damn dat is mooi klote man. heb de foto's gezien dat je mx werd weg geduwd.
hoop voor je dat alles goed komt en je weer snel van je wagen kan genieten :bier:
Mikee, I hope to see you soon on the road again with your new engine. It was a really sad saturday morning. I hope you and your grilfriend (keep forgetting her name :oops: ) are over the shock and can go one. I know how much the car meant to you two.
I wish you al the luck with the rebuilt of the monster. And you know, if you need some help, you know hou to contact me.
Good luck friend.
Gr. Dennis
damn mate!! bad news!!
1 tiny switch can make all the difference, so it seems...
new kl-ze on the way? and with turbo? i will give you a call tomorrow.
i know the feeling
also blow up my kl-ze in germany :(
i'ts pretty fucked up :nut:
goodluck with the next kl-ze and the turbo setup
Hey miguel,good luck with placing the new engine!!
I hope to see you soon with the new KL-ZE and turbo set-up!!
Keep it up man!!
