racing seat install
gregorychristian
racing seat install
Bericht door gregorychristian »
please post pics of racing seat installs or brackets
for every seat theres an A$$ !
hello gregory,i`f just placed your topic in another topic.
this topic is only for projects of your own car.
yuo can find your topic in the cafe
Tiga
Bericht door Tiga »
I've got some pix of my Mazdaspeed seats install. It is still the beta-version :) Some things I still have to change.
Centerconsole side
Door side.
I chose this set-up because now the seat is lower than the original. If you adapt the original rails and raise the doorside the seat will get higher than the original.
Hope this is what you were looking for.
NB: is dit topic niet beter op zijn plek bij overige Tuning? Heeft tenslotte niks met bierzuipen, vrouwen versieren en slap geouwehoer te maken :mrgreen:
Nightrider
Bericht door Nightrider »
Try also to put them on your original slide system.
You need to make new holes to connect the seat.
But watch out ,,, the doorside of the slide is 5cm lower than the other side.
My seats are standing on the original slides. But now they are sitting to high.
Ik got to go to the system like on the pics here above.
But you can try the original slides first. Than you can stil move your seat.
Sorry for my writingmestakes :mrgreen:
Nightrider
Dat heb je knap opgelost.
Ik ga ook op dit systeem moeten overgaan want mijn zitten nu te hoog.
Maar ik ben van plan andere zetels te kopen , nog niet meteen hoor.
Maar ik vind het makkelijk om ze te kunnen herzetten , nu m'n zoontje z'n koets er soms mee in moet. ;)
gregorychristian
yes I have mine in but they are way to high ...I hardly have no headroom, and need some new ideas ...ayone else have pics ?
sorry , same problem here
also no head space , but i don't mind , because i'm not so tall ;)
No pics,but same problem here.
I had to weld new mounting-brackets to lower the seats,but now I can sit with my head up. :mrgreen:
hyperman
Bericht door hyperman »
I have no problems with mine. they are on nearly the same height as the beam that run beneath the seats and in the back a i have a bar with a slight bend to fit both hole but it lowers the seat a little.
