16V: Chiptuning
It's a possibility but you would have to do it in combination with several other things like change the air intake and changing the exhaust this way the whole line get's adjusted which gives the most benifit.
Personally I would say turbo it. This takes some more time and money but the effect is much more
Aha.
Can you advise a good air intake to me?
Now I have got an OEM-air-intake.
Also I have got an Sebring-Exhaust.
But with an OEM-catalyser.
I asked at HGP for a turbokit. But I don't get an answer yet.
They have got a turbokit for the Mazda MX-5 (Miata) 1.6 for 4.800 EUR.
It's really expensive.
Greetings!
Tom
Greetings!
Tom
here cost the turbo kit 3500
only you must buy a intercooler and blow off valve and piping etc
http://www.jeroentje.nl/index.php?page= ... id=7015040
i think if you scearch on the internet , you will be a lot of cheaper
- MarcX3
MX-3-Tom schreef:But with the jeroentje-turbo-kit the engine-power also gains only 15% (~15HP)...
Only a Turbo gives a engine not much horsepower but with ajustments of the chip and camshafts you gain a lot more power and you can always boost it with a higher pressure but is less safe
But the main reason that people are in love with a turbo is because it dont give that much HP but it gives an very high torque and that is what you need with sprints
- NightQrawler
MX-3-Tom schreef:Are there any cheaper possibilities to get mor HPs?
I don't think so.
Had anybody of you here made some experiences with chiptuning a 16V DOHC?
Nos.. nitrous express.
but for 450 you have to buy an used set on ebay or something,
for approx.650 euros you'll have an new one.
if you spend a bit more you can get more show effect, especcially when you also get a purge system.
Look on http://www.mashamoto.nl or contact him. he's a member of this forum too.
MX-john schreef:MX-3-Tom schreef:Are there any cheaper possibilities to get mor HPs?
I don't think so.
Nice try, but it's illigal in germany
- marcel v6
- Bouwjaar: 1994
Ja John het is zwaar verboden om met Nos te rijden in Duitsland Met Gas moet je kokenMX-john schreef:MX-3-Tom schreef:Are there any cheaper possibilities to get mor HPs?
I don't think so.
- Yence
-The turbo kit @ jeroentje is for the SOHC anyway.
-The DOHC does 0-100 a bit faster compared to the SOHC, not 10,5 sec. as said before, but 9,7 sec. Not a huge difference, but still
Have you ever considered a powerboost valve? It's much cheaper. You won't gain as much hp as chiptuning, but torque will improve and it should compensate more then enough for the 18".
