Pagina 2 van 2
Geplaatst: 07 aug 2006, 22:51
succes met het plaatsen van de nieuwe motor!
Geplaatst: 08 aug 2006, 03:13
door NightQrawler
pretty f#cked up man.
Nos is always tricky it seems,
i wish you all the luck, i hope with the new engine you can finally use the bigger Shot of Nos.
Geplaatst: 08 aug 2006, 07:26
door mx almere
I thought it was pretty sad. You said "If you play with fire..." but this was the worst time it could have happened. So far away from home and before getting a chance to launch it on the track.
I hope you will have better luck bringing it back to life. If there is anything we can do for you, just let us know, ok?
Re: Nitrous Fusion is Overleden.............Mikee Blows the
Geplaatst: 08 aug 2006, 21:57
door Brayman
JD GRAFFIX schreef:I turned the key just a bit the wrong way...CONTACT!!!!!BANG!!!!!!!!!!!
after a good inspection it turns out that the New Activator Switch I had bought worked on Reverse, compared with the switch I had....so it was always on...Aint that a bitch!!
:cry:
Is the new engine also a ZE from Malaysia? I never saw this before...
I hope that everything will be okay with the new setup!
Best regards,
Brayman
Geplaatst: 09 aug 2006, 21:03
door donky
hi mikee,
if you told me "if you play with fire..." i know what you mean.
i`m looking forward to see your mx-3 on the track with a new setup.
i think there was only one car at the meet that was going by 6 manpower.
greets donky
