succes met het plaatsen van de nieuwe motor!
Nitrous Fusion is Overleden.............Mikee Blows the KL-Z
- NightQrawler
I thought it was pretty sad. You said "If you play with fire..." but this was the worst time it could have happened. So far away from home and before getting a chance to launch it on the track.
I hope you will have better luck bringing it back to life. If there is anything we can do for you, just let us know, ok?
Re: Nitrous Fusion is Overleden.............Mikee Blows the
JD GRAFFIX schreef:I turned the key just a bit the wrong way...CONTACT!!!!!BANG!!!!!!!!!!!
after a good inspection it turns out that the New Activator Switch I had bought worked on Reverse, compared with the switch I had....so it was always on...Aint that a bitch!!
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Is the new engine also a ZE from Malaysia? I never saw this before...
I hope that everything will be okay with the new setup!
Best regards,
Brayman
