Scary has a power boost valve from Malpassi with a double membrane.
on a conventional adjustable presure regulator when you give gas, it will raise the preasure by 10psi, but the version that Scary and I used goes up by 20psi. (double membrane)
The preasure at wide open throtle on the fuel rail is around 41psi, so if you set the boost valve while on iddle at 41 psi, when you give gas it will go up to 61psi, and thats just a bit too rich.
oh BTW, I hope you bought the optional meter that goes with it....otherwise its very hard to tell what preasure its set at
